I see. So I may have a bad guage then. I do have the solid state voltage limiter for the guages, but haven't installed it yet. I'll try that and if I still have a problem, maybe a new guage will be in order. Thanks for the help.
Frank
Here's one thing you might try. Replace the gauge sender with a resistor (you should be able to get them at Radio Shack) You need a big wattage wire wound resistor, and probably don't want to hook it up longer than it takes to check the gauge.
According to the info I have
L = 73.7 Ohms (empty)
M = 23.0 Ohms (1/2)
H = 10.2 Ohms (full)
Those resistances don't have to be "that close" Fer 'xample, anything from 70-75 should give you pretty close to MT
Another thing you can do with clip leads is to
1 disconnect the temp sender wire and make sure it is not grounding out, temporarily leave it hang.
2 remove both nuts from the gas gauge unit, this will disconnect the gas gauge from the circuit
3 use a clip lead and jumper the fuel tank sender wire connection (at the cluster) over to the TEMP sender wire. This will turn the temp sender into a "gas gauge" and you can see if they read the same.
This might give you a clue as to whether the gauge is correct / not or the sender is wrong.
My usual rant on cluster problems:
1 Power to the cluster connector pins, due to broken/ corroded pins
2 Problems with the voltage limiter
3 Problems on the PC board, including bad connections at the limiter, corroded nuts at the gauge units, and bad pins again on the cluster connector going out to the sender(s)
4 Poor ground at the cluster. work/ tighten/ loosen all the ground screws holding the board down, and attach a separate ground wire, bolted securely to the dash brace behind the panel, leaving enough slack to get the dash in/ out
On my own 67, the "socket" (springy brass fingers) for the limiter was not really making connection to the board, I had to jumper solder connections across from the brass to the copper board. The nuts were loose / corroded on both gauges, and several of the cluster connector pins were damaged. I replaced the connectors with "Molex" style from Radio Shack
