Hi I am troubleshooting my faulty fuel gauge.
First I found a broken connection behind the kick panel. Thought I had it but no, still a no go.
Right now I have the instrument panel out of the car for testing.
I actually have two of them and both are showing the same behavior.
I have 12V going to the post that powers the fuel/temp gauge and oil and E-brake lights.
I have the case grounded also. I can test it by providing ground to the e-brake light and it works fine.
When I test the output of the regulator (going to the fuel and temp gauges) I get a pulsing on my meter. Nothing that I can really read. Should I be able to read a voltage there? I have read in other threads I should 3-5 volts (?)
Not sure if that regulator thing is bad or not. I also ran a ground wire to the other side of the gauge which should make the gauge go to full, but it still does not move.
Thoughts? Thanks!
Thoughts? Thanks!
