coffeedart67
Working on replacing my fuel line (tank to fuel pump)with The Right Stuff ordered from jegs. Have it pretty good up to where it goes under the frame by the rear end. Where it hooks to the fuel line to the tank is about 2 inchs to far to the center, and it is just touching the shock. Judging by the trail in the undercoating it looks like it is supposed to go between the trunk floor and tank and it is forward about 2 inchs. Getting really annoying, think I am going to drop it and keep bending on it until I get it close to right or break it. Don't even know if I want to attempt the brakes lines I bought at the same time, the line that goes from prop valve to drivers side brake doesn't even have the right fitting for the prop valve. Don't remember when I ordered them or know where a reciept is so returning them is probably out of the question.
Any advice or pointers.
Thanks
Aaron
67 Dart GT Conv. 273 2barrel, auto 7 1/4
Thanks
Aaron
