Fuel Line Routing
440plus6
Simi Valley, CA
Does anybody out there have pics or a diagram of the routing of the steel fuel line from the tank forward for a later model A body? I got the new lines for my 73 Dart Sport but can't quite figure out how they're supposed go. Thx.
Nobody? I bought the car as a roller-fuel lines had already been removed so I've got nothing to follow. Was hoping someone would have some help so I can route the line from the tank correctly.
What happened to the old ones?
I just installed a 3/8" stainless line on my '74 Duster. I can probably get some pictures this afternoon if no one else has any laying around.
Shouldn't be that hard to figure out. There should be holes all along the passenger side for the clips.
Up over the axle.
Along the pass side.
Through the hole in the crossmember.
Along the the engine compartment rail.
Your in.
Thanks. With all the bends in the tubing, I was hoping to get a pic so I wouldn't have as much trial and error getting the line in the right spot.
this is going to sound a like off the wall but i think my hanes manul has a pick of the under you my or my not be able to see it there. hope this helps
