Fuel lines and return line
73hcode
Long Beach, Mississippi
Ok my car has been apart some time and I am putting it back together slowly. I can't remember the routing of the new fuel lines I bought. I bought 3/8 inch line and 1/4 return line I know it goes through the front crossmember but can't remember much more. I have the 73 service Manual but no pics in there any help with pics would help. I think I am getting old. :eek:ops:
The metal line to the pump came from under the frame rail sort of near the fuel pump. Less than 6 inches of rubber hose connected to the pump inlet. The vapor tube continued on to a charcoal can behind and below the right head light.
A picture is worth a thousand or more words.
Good luck
This is on 75 Duster - goes from engine bay along passenger frame rail through hole in crossmember near torsion bar. (2 piece vent line is connected with hose )
They hang from the first support bracket and clips behind the next one then goes back along the rocker
At the wheelhouse they go up and over to the frame and then under it.
Then back the inside of the frame and over to the tank
Thanks very much for the photos. When he asked about the crossmember I had K member in my head
