flathead31coupe
Anyone recommend a pump lol
So you would recommend the Mallory 250 for my application?
I used a used one and a new one. Both have issues.blue HolleysAn old noisy Holley blue pump would foot the bill.
I'm checking into a Mallory 140Those pumps are junk.
What makes the fuel pumps go bad? I mean I've looked inside both of them and they look pristine. I don't understand
I said OLD holley blue pump. Mine is 30 yrs old works just fine. Keep a rebuild kit just in case. If you want to donate one of those Mallory 250s, I wouldn't object.Those pumps are junk.
That's why I was asking early on in my early post. I had one used one that was doing the same thing as a brand new one was doing. Even after I put a 19 lb spring in the new one and deadheaded the regulator. I could only get about 11 lb max and it took about 45 to 50 seconds to get to thatI said OLD holley blue pump. Mine is 30 yrs old works just fine. Keep a rebuild kit just in case. If you want to donate one of those Mallory 250s, I wouldn't object.
Just ran 10.66 with junk blue pump.
i found a 250 for 220$Just so I know, what is old to you? I bought my first Holley blue pump in 1984. The second a year later (for my tunnel ram set up).
By 1986 I had to have both of them rebuilt. The company that did them said they had garbage brushes and they were made as cheap as they could be.
After he went through them they were more reliable, but the biggest thing that made them reliable was the return line.
LOL…I’m down to one 250 pump and I’m using that one. They aren’t coming up used so much any more. Pretty good swap meet coming up in January and another HUGE one in April and maybe I’ll get lucky and find a few.
I called summit racing. They said it would work. Fantastic! Not to worry updates will follow updates will follow about it so I went ahead and purchased it. I got it for $160 bucks
So if I do need a bigger return if I can't get the fuel pressure down can I just come off the side of the pump back to my tank with a bigger return and block the return up front at the regulator or is it better to use the regulator up by the carburetors and run a bigger line all the way backThats a smoking deal. Just remember if you can’t get the fuel pressure down with that pump it means your return line is too small for the fuel you are burning.
IOW’s, you are bypassing more fuel than the return line can support. You don’t want the return line being the restriction. Just the regulator.
If you can get the pressure where you want it then your return line size is fine and you are pooping in the tall cotton.
Keep us posted please.
Just curious....So if I do need a bigger return if I can't get the fuel pressure down can I just come off the side of the pump back to my tank with a bigger return and block the return up front at the regulator or is it better to use the regulator up by the carburetors and run a bigger line all the way back
Just curious....
I knew that I read that in your last post. I was wondering should I come from up front on my regulator by the carburetors or block that one and use the return at the pump?Bigger return
