Im looking for a spot to plumb in a fuel pressure gauge. Using Braided line and holley regulator dual carb setup. Wondering if this fitting could be drilled and tapped to fit?
From the regulator Im running a line from each port to the carb. Ive seen the inline piece in order to use one id have to splice the line and dont want to do that. I would like one solid line from the reg to the carb
then get rid of that POS banjo fitting and run AN fittings that have 1/8" plug. buy a new reg that has an 1/8" pipe, make a new log assembly that has an 1/8" pipe.
If you are pluming it all in new run AN fittings, super easy, they sell fittings for the 600 holley.
Using AN fittings you can put the regulator anywhere you want.
Keep in mind the closer to the carb the better, but mounted on the fenderwell the gauge will have less vibration and be easier to read.
Here is a pic of the an fitting going into the same style carb you are using.
I am pretty sure this fitting is 5/8 x 6AN male, I can take it off if you need me to but the right fitting is only like $10.00 and will eliminate the banjo fitting you have on your carb.
