Fuel Pressure Regulator
65 Dartman
1 of None 65 Dart Sedan Delivery
Strasburg, VA
I have the Holley in-tank FI pump with the built in pressure regulator and no return line in prep to run the Sniper. Prior to installing the Sniper, I am planning breaking the not yet assembled engine (273/235) in with a carb. Is there a fuel pressure regulator that drops the FI pressure of the 60 PSI down to what a carb would use?
nope, it will not work that way
it if were me, id hook up a mechanical fuel pump to the engine and see if that will draw through the electric fuel pump
if it wont, just grab a 2 gallon gas can and draw from there, shouldnt be an issue if it is only for freak in
Gallon jug above carb with its own line from it. Pull fuse on pump. Have an extinguisher ready in case.
the pump is to be powered by the Sniper’s dedicated pump harness through a relay in my fuse and relay center. The Relay will be protected by a separate fuse
Yes.
This is the one I am using.
you can use a bypass regulator to go from 60 psi to 6 psi but a return line is needed .
