hey guys, i got all the fuel lines run finally, but when i turn the pump on, at first it just sounded normal, but didnt build any pressure. then fooling around checking to see if fuel was actually making it to the carb, now it sounds like it primes, then looses prime and prime and looses prime, and the gauge corrispondinly goes from 0 to peging the gauge-back and forth. im not really sure what the problem can be. i thought maybe air bound, but it has fuel right up to and into the carb. its a return style system, areomotive A1000pump, regulator and filters, i have a #12 off the fuel cell into the first filter, then #10 for the feed and return lines. any ideas here?
--chad
--chad
