A1000 Aeromotive
Walbro GSL-392, they are cheap flow serious fuel and are very quiet.
gsl392.com
I am using multiples on my current project with carb & E85 conversion.
You can see my set up on the last couple pages of my scamp tread in my signature.
x3 on the Walbro
I wouldn't call it quiet, but while the car is running you definitely can't hear it, but you can hear it whir when you set the key and are about to start, which is a good diagnostic sound at least.
Lol. Try that with any other inline fuel pump that flows serious fuel. They all sound like a 4 stroke chainsaw WITH the engine running! Not to mention the rattles of the car that come with using one. I have ran 3 Walbros all at the same time and you can not hear them with the engine running.
If you like the sound of a chains saw then sure! haaaa
Just ordered the walbro
I do have a regulator but not a return line. I guess i will have to run one. I just did'nt need one with the carter pump.How much power you are going to be making?? You may need 2 or more.
You will also need a regulator and a return back to the tank if you don't already have one.
I use this one from Mallory for a carb set up with the GSL-392
http://www.summitracing.com/parts/maa-4307m/overview/
and This one for Fuel Injection.
http://www.summitracing.com/parts/maa-4305m
I suspended my GSL395 pump (15 psi version of the GSL392 which is 60 psi) about 1.5 years ago and I can't hear it running with the engine off! There are two self-stick rubber bumpers stuck on the chassis side, but I don't know that they've ever even made contact.
Note that the about to kink hose has been replaced with a 45° hose end and slightly shorter hose.
I used the stock 5/16" supply tube for the return and added a 3/8" supply. Am using a Holley By-Pass type regulator and its output pressure is inconsistent at best. Sometimes it's 7 psi, sometimes its 9 psi.
That's "emissions barrier" fuel hose on Push-Lok fittings, which is why no clamps. That hose has what appears to be a teflon or polyethylene liner.
Yeah, my A1000 is loud... Until the car fires off, then I promise you can't hear it anymore. ;)
More push-on... My entire fuel system uses it; no problems.
