Is there a formula to determine the correct fuel pump, line, and sending unit per application?
I'm building a 470 Indy EZ headed BB roller street car motor and wanted to use a mechanical fuel pump. I need to know if its better to run eletrical and block off the mechnical spot on the block of will the mechanical work? I estimate the motor will produce 625-675 crank hp, with 950 QF carb.
I was thinking of using 1/2 or 3/8 sending unit and mechnical fuel pump, but next year if I can find some $$$ to add 150 shot NOS. The car will be pump gas streetable and running 9's with juice, low 10's N/a:burnout:.
