MOUSE
Does anyone have a way to use a gm sending unit , in a fuel cell, with a factory mopar gauge ? :sad1:
brother . I appreciate your response but I'm talking about a 70 pro street dart. the biggest electronics in it will be the stereo. unless this is april fools .... took me a min. thanksMouse,
With a small software change, the gauge calibrator circuit should do it. This is only an option if you work with electronics. I can send a chip if you build the circuit.
http://www.forabodiesonly.com/mopar/showthread.php?t=264543&highlight=calibrator
Here is schematic.
Mouse,
Here is schematic.
I had planned on doing a custom dash . so I got a fuel cell with a gm sending unit because most aftermarket gauges are set for gm. anyway my plans changed and it looks like I'll be getting a mopar sending unit.Let me ask you this.........why do you want to use a GM sender?
