has anyone tried to add an intake fuel pump to the stock a body sender? questions if you did: 1) what did you use to put the wiring thru the sender plate?
2) did you use a 5/16 or 3/8 sending unit? 3) where did you put the return line if you had that kind of system. tia. rick w.
