ive noticed that when looking at my gas gauge, it seems to work fine until it reaches 1/4 of a tank. then it seems to hang or not quite work as smoothly as needed.
is there a way to fix this issue to where it works more accurately, or is there a reason this is happening? today it showed i had 1/4 tank of gas, i put in $10 which then showed to be 1/8th of a tank. then it came up, then down.
any suggestions as to how to cure some of this issue to make it more accurate when 1/4 tank or less?
