[WANTED] FUEL TANK SENDING UNIT, F body
You need a sending unit for a 77 Aspen?
Is it the later style or does the car have a round spare tire well?
I think the only difference between the late 77F and 79 or so and newer is its a 2 wire plug. The ground isnt a separate wire.
I prob have a good one for the late 77 up F body.
If its the 76 thru mid 77 style your likely S.O.L. Not only is the tank and sending unit different youd need to change the trunk pan to use the later tank properly.
Might send Whitepunkon nitro a PM ,Grey.
thanks brother, I will
looks like I need to swap trunk pans and tanks
i have a cheap tank new already, and might already have another trunk pan
i do need the sending unit Jim, let me know when you get a chance. :):)
I have a 78 aspen 4 door car... would the tank from that work?
