hellfirechrome
Hey guys! I've got a '66 Signet /6 that needs a gas tank and sending unit. What line size should I expect? 1/2" 5/8", etc.? Ebay shows a bunch. Thanks!
I can only reply as a mechanical/aerospace engineer who has designed fuel systems for aircraft engines. There are some amazing "technical facts" spread around by the unschooled, but that is an amazing one. Perhaps you mis-read or mis-quoted. Anyway, there is no way you would have more pressure drop through a larger diameter line (assuming it stays full of fluid and other caveats).The subject of overworking the stock fuel pump with a 3/8 size fuel line came up in another thread I read here a while back. Someone said the stock pump would have to work harder to suck the fuel through the larger line. Is there any merit to that, or is that B.S.
