donald smith
Member
can the casting snub b removed for pump clearence passenger side engineblock 340
Thanks for the input ive never had to doit but some hp pumps will not clearYes, you can take some of it off. I’ve never milled one down to the block so I can’t say you can take it all off.
IIRC you need to take somewhere around .200-.250 off to get the pump to clear. I take just enough off to get the pump in there.
On most early la engines on the pass side of the block were fuelpump diaphram sets is a casting stickingout about 1inch an a half about like the end of a hot dog weinnie and on some hp aftermarkit pumps wont clear itToo bad you folks won't explain what in heck you are talking about.
If you fool with enough ofem you sooner or later will when you use a pump other than stock pumpThis is a first for me! Never heard of fuel pump clearance issues
i just looked at another 340 block i have and you can stick your finger all the way in and around that area behind the snub through the freezeplug hole its flat all the way so id say you could remove this snub all the way to the block with no issuesYes, you can take some of it off. I’ve never milled one down to the block so I can’t say you can take it all off.
mabi this will help other mopar lovers in the future thanks again for your interest when you want to go fast and hard in a mopar and b first alot of times you have to do what the manufacture didnt..... mopars 4 everHere is a pic I just took, the boss is pretty close even on a stock pump.
Your wife told me that you had an offending nub.Yep, thats the offending nub right there.
LMAO. Just know I share your malady. lolOh yeah, she will swear to that in court. Of course, she got sick yesterday so that’s my fault don’t you know lol.
So, I’m pouring DayQuil down her as fast as the law allows. I get a dirty look because it tastes bad. And yes, since she’s sick that’s my fault too because I didnt get theraflu, which no one around here has for some reason lol.
So yeah, the better half has way more grievances with me then the aggravating, offending nub!!!
