rustytoolss
Will using full groove main bearing lower your oil pressure ? If so how much ballpark ?
I'm getting about 52 psi cold, and around 12-15 hot idle with 10w30...
For me, any pressure below 20-psi is 'worrying'.
The cambearings could still be the cause of the low hot oil pressure.
More oil volume could help keeping the pressure up a bit.
Or change to a 10w40 oil perhaps.
I think they make a 3/4 groove
I agree ..under 20 is scary. I will probably put in a HV pump. I guess I could even go 20W50.
Take a look at this sticky:
http://www.forabodiesonly.com/mopar/showthread.php?t=103623
To support the full groove bearing with proper flow and pressure you need to clean up the supply passages as well as run an HV oil pump with a pan that can hold at least 6 quarts of oil. I've also done the mods mentioned in this sticky, as well as removing all the casting flash, to allow for faster return flow. Although I haven't run my engine yet, I'm confident this will greatly improve the life and durability of my 340. I'm sure these mods are good across the board for small blocks.
Absolutely ZERO wrong with 10 PSI at idle with a stock volume pump. NOTHIN, NADA, ZILCH. You ever tried to hold back 10 PSI on something with your thumb? That's enough to slobber oil ALL OVER the inside of that engine. Some of yall need to worry about important stuff.
I put a different gauge on it, and am showing 17-20 psi hot, so after what has been posted. I will drive an see how thing go. Thanks guys
That's plenty adequate at an idle.
What do you get at 2000rpm, 2500, 3000?
If you put a high pressure spring in it that will NOT help IDLE pressure. The pressure relief is not open at that flow rate, the relief is only there to limit MAX oil pressure. To increase idle pressure you need to increase oil flow, that is why the pressure goes up as rpm goes up. a high volume pump will increase pressure at idle but increase load on the pump drive, add to the possibility of aeration of the oil ( as it sprays from the pressure relief ) add heat to the oil, etc. I've always heard 10 psi per 1000 rpm up to 50-60 psi was good, I do not claim to know for sure on that but I would not worry about 12-15 at idle. Cleaning out the restrictions in the oil passages should not lower the oil pressure unless they were restricted before you cleaned them. Oil pressure is a function of the oil flow into the system vs oil flow out, and viscosity, period. The clearance on the bearings is specified to allow adequate oil in and a certain amount of oil out ( to cool the bearing). If the clearance is to great then you will have an oil pressure "leak" that can only be fixed by reducing the "leak" or increasing the flow. If the pressure comes up to over 50 psi before you get to 5000 rpm and stays above 10 at idle I'd be happy. Full groove bearings should not lower oil pressure if the clearances down stream are good. It would reduce restriction at the crank but if cam bearings are good and lifter clearance in there bores is good should be no problem.
You are having a problem with PRESSURE, not VOLUME. It makes more sense to use a high pressure spring to increase your pressure versus trying to throw more volume at it. However, It wouldn't hurt to go with the high volume oil pump AND the high pressure spring.
Those mods are good, but I feel that they are overkill on a street engine. IF you are going racing, then I would use some of them.
Opening up your passages will REDUCE your oil pressure. Pressure is force over area [pressure = (force/area)]. So if you increase the area, you lower the pressure.
Simple engineering... If you have a surface that is wearing under a force, you increase the area to reduce the net force per unit area. :read2:
will a high volume pump help ?
The reason he's having an issue with pressure is because he doesn't have enough volume to support the natural oil leaks inside the engine which in turn caused a low oil condition. Increased oil volume should increase the pressure also. Remember pressure is the result of restriction in the oil system.
Simple engineering... if you have too low of pressure because your pump can't put out the proper volume of oil to compensate for the larger "internal oil leaks" then your pressure is going to go to crap.
Yes opening passages will reduce pressure because you reduced the amount of restriction in the oil system, in turn supplying more oil to key critical areas. in order to support the reduced restriction in the oil system, you will need to run an HV pump.
Here's something to ponder upon: If you opened up the oil passages in your oil system but left the openings alone in the bearings, and you have a reduction in oil pressure, what does this tell you? The restriction was the supply line the whole time, and the bearings can support more oil flow (volume). Who in their right mind would not want more protection for the engines critical areas (main/rod/cam bearing)????
Here's a very good article:
http://nzetc.victoria.ac.nz/tm/scholarly/tei-Gov04_02Rail-t1-body-d22.html
I think you might be confused about boundary layer lubrication... Internal combustion engines use hydrodynamic lubrication because the oil is the load bearing member and the development of the oil wedge is dependant on the rotational motion. With boundary layer the surfaces are the load bearing members. Least that's how I understand it.
Also in regard to having high indicated pressures... The oil pressure tap is off the lifter galley in smallblock Mopars. If you are pumping a ton of oil into the system, you are not reading what the mains are seeing. You're reading what the lifters are seeing and hoping that this indicates the mains and rods are getting enough. If the passages to the mains are left at factory size, you are not "seeing" the bearing clearance in that reading because you're pumping so much oil into the galley. Pressure is resistance to flow and what it indicates can be doublesided. You have to make sure that the higher indicated pressure isn't resistance caused by passages that are too small or too much of a volume entering the system. Otherwiase you're using a bit of power to make a bunch of heat.
