In my case all bad. perfect 383 69' Coronet. It started up ran on eight, then it after 100 miles or so it would shudder, run erratic and die. Start it again, go down the road, and all over again the same thing. I got it home, and tested for compression, which was 70-90 all around. Also, I had an oil leak around the pump, that wouldn't quit. I called the engine shop, and asked what is the deal. The first question was, what oil? I told him, and he said get that crap out, NOW. I ran Rotella 15-40 in it Immediately. The engine smoothed out within minutes. The engine ran like a million bucks, and the oil leak quit. 5,000 miles later, it drives better every time I start it up. Synthetic won't seat rings. Several restorations later, I always use Diesel oil with Lucas #10036 for lifters. No problems since.
