danielb927
I'm going to a functional scoop so I figured I'd share a couple photos with you guys. Didn't want to cut too much of the hood up, so I bought a 24x24 aluminum sheet and had it cut out on a water jet to match the triangular shape under the scoop between the hood supports. Riveted to it the base from a 9" K&N flow-top air cleaner. It's intentionally a bit off-center to line up with the hood supports. Here's what it looks like without the filter and foam:
Still to-do: add the foam sealer around the edges of the plate, cut out the hole in the hood, and that should be about it. Maybe add a support rail under the front of the plate if it flexes too much.
Is it even worth trying to cut out the hood hole by drilling a starter hole and using a mini-hacksaw, or should I just suck it up and find someone with an angle grinder? Not sure how thick sheet metal is so I don't know how bad it would be with a hacksaw.
