FYI 833 Iron to Aluminum bell housing swap WARNING
trapster
Central Florida
If you swap out your iron bell housing for an aluminum one, DO NOT REUSE the bolts that held to 833 to the iron bell housing they are about an inch too short and will pull out eventually.
Ace Hardware has some nice grade 8 2.25 inch bolts that should work fine, if you cant find original ones.
LMAO! Oh! Those DANM little things in life that throw us curves to overcome.
Good lookin out!
