FYI on Motive pressure bleeders
SGBARRACUDA
ROY
Legendary Member
PLANT CITY FL.
I thought I would pass this information on to those that need a pressure bleed system. Years ago I had bought a Motive pressure bleeder for the old bail , cast master cylinders. The part number is 0105. I worked well on the old cast dual master cylinders. But this time I needed it for my latest build, my 68 Barracuda with the late model aluminum master cylinder with the plastic tank. I went on Ebay and bought the adapter kit I needed, which is part number 1113 to use with my old system. Today I bleed the entire new brake system with this set up today. And it worked out Great! I highly recommend this set up, especially if your a one man show like I am. Only used about 3/4 of a quart of brake fluid.
Is it cast iron or aluminum? 0105 for the cast iron, 1113 for the aluminum with the two plastic twist tops.
Cast iron cylinder with plastic tank and twist caps
EDIT: Decided to gravity bleed instead. Thanks
