skips dart
Thought I would bench fit a new Quick Time Bellhousing to my # correct 69 4gr Dart.Glad I did as I found that the clutch fork pivot bracket they supply is 1/2" out of position and would have caused clutch pedal binding if installed as is.I called them and asked if I had the wrong pivot bracket but they said no--- and informed me that some earlier fork mounting required the position to be moved?????and said they might be adding extra holes in the future to correct this issue.So I drilled and tapped 2 extra holes 1/2" away from the centerline of the bell housing bore, now the fork tips are sitting correctly on the centerline of the release brg.Maybe this has already been discovered by other guys but I thought I would throw it out there.
