If it doesn't have gas ports it gets gapless top rings.
Jenkins was correct. You are always going to have some blowby. Even the very best of the best have some. There is a cumulative effect, especially as RPM goes up. You need to run the SECOND ring gap wider than you normally would to get the blowby past the second ring. If you don't, no matter what you do you will unseat the top ring.
I've done more testing on this than it was worth. The better the block, the hone and the piston the less effective the gapless top is. If you are at that point you should be using gas ports.
If you want to see how well a gapless top ring works, do the best prep work you can on a 400 Chevy block and use conventional rings. Put it on the dyno and put a blowby meter on it. Then do nothing but change the rings to a topless set and see how much more ffective they are.
