[FOR SALE] Garage Cleaning, Round 2
Sedanman
67-9 Valiant specialist
chicago Il
Round #2 of my clean out in Chicago,pick up will be easier on me or if it fits in a flat rate box, the shipping is on you.
Dana 60 to 727 driveshaft for 108 wheelbase A body with yoke $125
nice factory 360 car pan (392) and new matching pick up $75
Small block spool mounts,$75 for all 3 with block bolts,blasted and painted with good rubber
two cans of R12 freon with hose $60
Small block windage tray with bolts $75
A body manual brake push rod and bolt $25
pre 68 stock small block steel crank $75,prefer pick up
one pair of 920 closed chamber heads from 66-up 273's $150
two late 60's-early 70's 2 bbl carbs $50 for both
360? Cast crank balancer,blasted and painted street hemi orange $40
73-up spool trans mount frame,bushing and trans bolts and spacers $60. These can be used on the pre 73 cars by making the holes larger. I prefer them on my cars.
is the 360 oil pan compatible with the 1998 5.9 magnum motor?
Yes, & the sump on the 392 pan starts 4" back from a vertical plumb line straight down from the very front pan lip. (needed for an early A app) & the sump is ~8" long. Use a 360 gasket.
I’m interested in the Freon. Thanks Tom
Sorry,I was trying to shake a cold. I still have the pan and pick up and I cleaned out my inbox. Sorry guys
