just trying to clean ouy my garage a little. all items are located in Ephrata PA, 17522. 10min north of lancaster PA. all prices are negotiable.
5" autometer phantom tach. with shift light. part #5899. nice shape, just a few small scuffs. nothing major. works great...............150.00
black and blue recaro seats from a chevy cobolt SS. nice shape. some one got a little ruff with the drivers seat sliders, but they are still very usable. comffy seats...........150.00
demon 575 cfm carb. annular boosters, vac sec., elec. choke. worked great on my mild 400................................250.00
manual rack for an alterkation front end. very low miles. i went to power steering...150.00
68 383 2v long block. i bought it as a running motor. never heard it run, but i don't see why it woulden't. spins freely, pulled heads and #1 main cap to check things out. looks fine. small cyl. ridge.............................150.00
77 400 long block. ran when pulled. 906 heads, magnum cam. low oil pressure. would call it a core.......................150.00
187 BB oil pan and 3/8 pick up. notch for idler arm. looks like someone scuffed the bottom on somthing at one point. not bad. dosen't leak.........................40.00
383/400 dp4b alum. intake. nice shape, threads look good. painted blue.....................100.00
msd 383/400 ready to run distributor. part# 8386. nice dizzy. used >1500 miles. i'm going 440 so i can't use it anymore...........................250.00
71 dart blue bench seat. nothing special. 1 or 2 tears..............free
3" summit x pipe kit with 3" dynomax ultra-flo mufflers. welded together. was on my 71 dart. had down pipes on it that have been cut off. just the x pipe and mufflers................................100.00
chrome ign. box with harness................................30.00
fiero seats. not in the best shape. i have seen these used in a bodys before. mount very low to the floor........................20.00
again, all prices are neg. would consider trades for stuff i need.
11" sfi flywheel
70-71 dart aar f.g. hood with cowl hood scoop.
440 performer rpm intake.
a body 4 spd. cast iron tail shaft housing.
in cell fuel pump set-up.
big block stuff
what else you got?
will ship smaller stuff, not the big stuff. local pick-up welcome.
im or call .............steve..........
if i don't answer leave a message, i'll call you back.
working nights right now, so please be patient. thanks.........................steve
11" sfi flywheel
big block stuff
what else you got?
