anybody have any suggestions? Pics and info on brand and price would be awesome! thanks a lot
If you're going through the trouble of coating it, DO IT RIGHT!!! I went through this with my parents garage two years ago, my father has a tight grip on his wallet and wanted to skimp on a few things. Do the prep work RIGHT!!! Get quality EPOXY!!! The concrete at my fathers was pitted and cracked, he didn't want to pay to get it grinded and re-topped, so I prepped it best I could. He also only wanted to use the Rustoleum product. After one weekend of prepping and painting, it held up for all of 6 months.
DO IT RIGHT!
Whatever you put on there, if it is not vapor permeable, it is guaranteed to fail if there is not a vapor barrier under the slab. Do your research on this. If you don't know if their is a vapor barrier, there are ways to check.
If there is a vapor barrier, go with the two part epoxy. Nothing beats it. This is what's used commercially in stores, warehouses and factories with heavy forklift traffic, chemical spills, etc.
What a dumb question.
Everybody knows it's the Color of the last parts you painted
So what type floor treatment would also act as a vapor barrier?
I don't think there is such a thing. The vapor barrier is the 6+ mil plastic that gos down prior to the slab being poured. If there is no vapor barrier, the slab will wick up moisture from the ground. (Think of concrete as a very dense sponge) As far as I know, nothing, no coating will stop it.
As far as the comments that nothing will hold up, I disagree, As long as the vapor barrier is in place. I have seen slabs with epoxy coatings that have lasted many many years, and still shine like a waxed floor.
There are no band aids. It has to be done right from the start.
