robjkc
I've been trying to get my 64 dart gas gauge working for several days after installing a new sending unit. It's always showed empty since I bought it. I did the grounding test which worked (although slowly) before installing the new sending unit but didn't after. I've checked the sending unit for resistance and also have it grounded with the metal strap.
After much trial and error I found out my sending unit pin on the circuit board did not have good connectivity to the board doing a continuity test. When trying to move it to get continuity I ending up breaking the pin. I eventually soldered it back on but after putting things back together my gauge instantly goes to full after giving the dash power.
It was recommended I go with the RTE external dash limiter but in the meantime I was wondering if anyone would know why the gas gauge pegs even though I only have a few gallons of gas. Also, I have someone sending me another dash cluster so I may need to use that as well.
Thanks for the help!
Robert
Robert
