Before I install my new interior into my 69 Dart GT convertible I want to get all my dash gauges working. My gas gauge sits on E. Any thoughts how I might go about testing it. There is 5 gallons of gas in the tank. Thanks and Merry Christmas.
Guys you cannot "test" a gauge in this manner other than a quick test which, really, shows you no more that "if" it is getting something for power and has 'some' functionality.
UNLESS that is you go through the SYSTEM and make somewhat certain all the elements are "correct" and in good shape, and THEN
Test the system 'end to end.'
1....With the cluster out, inspect, do wiggle and ohmeter tests and repairs
Some of what might be wrong:
Bad connection at the harness connector and or loose connector pins at the mounting point at the PC board
Bad connections at the IVR (voltage limiter) as the brass contact fingers are NOT soldered to the board traces.
Bad connections at the gauge stud nuts. Wiggle the nuts and or replace them
"Coming back out" once again possibility that the sender wire pin is loose on the board at the harness connector
There is always a chance the kick panel connector (fuel) or bulkhead connector (temp and oil if equipped) has a loose or corroded connection
And, there's possibility the wire end for the sender is loose / corroded
2...AFTER you go through all this, you need to attempt to determine if the combination of the gauge and IVR unit is working properly.
In this vein don't forget to improve the cluster ground and to make certain that the cluster unit is actually getting proper "full" battery voltage.
3....NOW finally you are ready to see if the gauge is somewhat accurate. You need proper 12V power and ground to the cluster , and you need test resistors to test gauge accuracy. You can either adjust the fuel sender by hand if you have it out to "set" resistances, or you can drum up test resistors from someplace like Mouser Electronics, Digikey or wherever you can find. Below is the rear of the factory test jig, AND THIS IS COVERED in the shop manuals
This has been written tons of times on here do a search
This thread here has a discussion on PC board repair
http://www.forabodiesonly.com/mopar/showthread.php?t=234045
Photo below shows repairs I made to my IVR socket which was not making contact. The jumper wires soldered in are for extra grounding and to connect 12V because with mine, I abandoned the original board connector
Another thread
http://www.forabodiesonly.com/mopar/showthread.php?t=284908
More info on gauge tester and resistors
http://www.forabodiesonly.com/mopar/showthread.php?t=329012
If you don't have a shop manual, a FACTORY manual, you can download them free from MyMopar
http://www.mymopar.com/index.php?pid=31
