Snake
Mopar Nut
Can our gas pedal be bent so we get more travell.My holley is not opening all the way in fact its only open 1/4#-o I have the v 8 cable the 340 bracket and the holley leaver.The pedal goes to the floor.So will that help.
is the gas pedal all the way up when your not touching it? you can adjust it under the hood where it bolts so the cable is tight and just bearly pulling on the carb linkage there should be no need to bend the pedal to gain what your looking for
looks like there might be a little slack in it, its adjusted all the way forward you can tighten it some by pulling the throttle cable towards the firewall. your sure to gain some as you still have some cable showing at wide open throttle. sorry didn't mean to come across as an ***...
Drill a hole or two down lower on the bracket (in red) then hook the cable to that hole. That will give you the throw you need.
The lower you go on the bracket the less distance the cable will have to go to pullthe bracket open.
Drill a hole down lower on the bracket. That will give you more throw.
I was having the same problem as snake is. Fixed her right up.
Don't think I can explain it very well but it will work.
