Gas Tank issue...
Silicon lubricant, guys; not silicon sealer..
I use the RoadRanger transmission O-ring LUBRICANT from Fuller; the most awesome LUBRICANT you will ever find for rubber parts.
Plus you can use to lube the belt on your treadmill.
I have used "Vasiline" petroleum jelly also, worked for me.
The underside of the belt, right?:D
I had a mouse that would come out from under the tool closet door and then run back under when I tried to smack him, so I got all smart and silicone sprayed the linoleum where he was coming out.
He came out but did a major burnout on the siliconed floor and I got him. :D
Problem came because I didn't think to wash the floor and the poor Wife walked through there in her socks.:elmer:
That stuff is murder to get off the floor.
Or anything else for that matter.
Welp I found the problem....
mnQBHmB6dWcxp56s-jtthsE9m4y85vfK5WHZ3TwTLQUTLPNDYNznfypY4YghR-mvTrHOTijFpwiRHs96yI2=w636-h847-no.jpg
