limegreen70
Pokorny Enterprise's
How do u remove old liner from a tank? It looks milky in color. Will acetone do the trick?
My friend works.in a rad shop. He said about hot tanking it. I'm not against paying to do that but if I could.find a cheaper solutionI took mine to the same radiator shop that installed it and they removed it. I don't know how they did it but they did. It let loose because the tank I bought was electroplated on the inside and I did not know it. It's so slick nothing will stick to it.
New tanks are pretty cheap. We cold tanked them. I forgot why. Hot tanking was out of the question. Galvinisation?My friend works.in a rad shop. He said about hot tanking it. I'm not against paying to do that but if I could.find a cheaper solution
I know new tanks are a good option but mine don't look that bad and it's original. I like to reuse stock stuff when I canNew tanks are pretty cheap. We cold tanked them. I forgot why. Hot tanking was out of the question. Galvinisation?
Why was it "lined"? New is hardly noticeable from an O.E. perspective. Your call.I know new tanks are a good option but mine don't look that bad and it's original. I like to reuse stock stuff when I can
I think it was lined because someone just thought it was the thing to do. And it was done sort of half *** as well. If like to at least get it to come.up and see what it looks like underneath. Go from there.Why was it "lined"? New is hardly noticeable from an O.E. perspective. Your call.
