What gasket sets are you guys using for the magnum engines? Is everything the same as an LA except the oil pan gasket? I plan on using the .028 head gaskets so I'll be buying those separate. Thanks
There is a lot of differences in Magnum sets and LA sets. What year engine do you have? What setup are you going with? LA timing cover or Magnum?
For me, I bought my set (2001 Dodge Ram) from RockAuto. Best price I found, cheaper than buying local.
Abodybomber is spot on if you are mixing parts.
What year LA, every one I have took apart most had a one piece thin metal gasket or none at all.
The fel-pro set come with the one piece and three piece.
I always wondered what year used the 3-piece.
Ye I bought this oil pan.
http://pages.ebay.com/link/?nav=item.view&alt=web&id=131287469880
And have a pickup on the way. I got the one piece magnum oil pan gasket, the timing gasket set I posted above and will probably buy this intake set.
http://pages.ebay.com/link/?nav=item.view&alt=web&id=191431199295
Sure looks like you are on the right track. Good Luck with the build!
I bought the 3-piece exhaust set (6 pieces) for a 68 318 engine, my original in the B'cuda. They are a pain to use unless you have studs. LOL
I decided against using the 318 manifolds and opted for some 92 Dakota manifolds. I had to do a little tweaking but both sides fit.
BTW, that's a really nice looking engine setup you have there, sireland67. You are just basically using the magnum shortblock? The rest is LA?
