You'll be sorry! Lower the back and prevent the destruction of the front suspension parts and tires. Just throw a **** load of weight in the trunk. Who knows you may even do wheelies.
Well, yes and no. You can to a extent. There is a point where you will not be able to align the front end if you go too high.As Oldmanmopar stated a combination of lowering the rear along with razing the front can get you close to the look you want..
I have a parts car and thought what the heck,
might as well have fun with the leftovers.
Wheel/tire combo will help too.But you won't be able to get close to the straight front axle look.
I jacked up my torsion bars on my 64 sport Fury. Took it for a high speed run. The front end started bouncing off the ground at about 80. Scared the **** out of me. I was 17.
