I assume what you are saying is that the temp and fuel gauge are giving problems?
There are a number of causes.
The harness connector to the cluster could be loose/ corroded/ ect
The pins on the PC board can be loose/ not making contact
The gauge voltage limiter (does not apply to Ralley dash) may not be making contact in it's "socket." The springy fingers forming the socket in the board may need to have jumper wires soldered between the brass fingers and the board
On either Rally/ non Rally dashes, the voltage limiter may simply be going bad. (inside and part of the fuel gauge on Ralley dashes)
The cluster may not have a good ground. Install a separate pigtail from one of the PC board ground / mounting screws, and bolt it to someplace like the column support
The gauges may not be contacting the board at the studs. Loosen tighten the mounting nuts of the gauge studs several times to "scrub them clean, better yet, put "real" nuts on 'em.
Check the sender wires for continuity, but since you have trouble with both, it's more likely troubles up in the cluster
