Gauges
mygtsissweet
Norheast
So all of the sudden my temp and fuel gauge quit working any ideas. They are right next to each other. See photo
IVR or dash current limiter works on both plus the oil gauge. That down also?
Hopefully the gauges aren't fried which is a common result of a bad IVR.
Looking at the photo in post #1 my bet is they are OK.
When my IVR failed closed (12V continuous) my temp gauge took a hit. the needle ended up a 1/2" too far left. still worked but never got over the low normal line. the fuel gauge was not effected. probably low on fuel and a lot of resistance in the sender
