Gen 3 carb intake
give you an idea from the side angle how low my elbow is.
for what it's worth lol the dart in the back ground uses Joe's ocp intake. the air cleaner barely touches the underside of my scoop. the vintage air fittings require the scoop also. the duster in front uses the full height ritter. both motors are at factory height.
just remembered and should mention the dart's carb is sitting on top of a 1/2" nos plate
Right on, Looks good! Thanks for the info!
Thought some might get a kick out of my choice of carb for the run in. I think it looks right at home.
Anyone have the dimension from the intake carb flange to the heads mating surface on these intakes?
