bricud
Cuda's Cuda
I have a '69 barracuda convertible with the weak 7 1/4 rearend. I was thinking about finding a 8 1/4 rearend to replace it with. There is one listed locally for $500 out of a '69 Coronet. It is open type and I would consider changing it to a sure grip type if possible. Is it worth it? I think it is a few inches wider than my A body unit based on what I read about the C body rear ends. The owner said he would take $250. To replace the guts would run about $450 if I use the same gears. It has 2.71 gear ratio. By the time I replace seals, etc I would likely have about $8-900 in it. If not this what should I look for that would work for my Cuda. I want to ne able to use as a weekend driver so I don't want super tall gears. I am not familiar enough with my options so I am hoping to get some advice. What I should really be looking for? I plan to run a 360 stroker about 450-500 hp. Can the 8 1/4 handle this or should I only be focused on the 8 3/4?
Thanks.
Thanks.
