GIFies no longer work?
diymirage
HP@idle > hondaHP@redline
michigan
does the forum no longer support the GIF style images?
you know, the little 2 second videos
ive added a few to my posts over the last weeks and they show up as stills, rather then little movies
the interesting thing is, when I attach them, they show the movement in the "attached files" bar, but then when I hit "post" or "create thread" they stop moving
Your's is working!
It has to do with the playback on your end, because the one you posted is working.
of course, that one works, ive had that one save on my computer for ages
could it be a format issue?
here is one I tried to post to pic on rainy
(I didn't see this one move in the upload bar)
Did you give it time to load? I have done that before.
yes, it seems like when they work, they work right away and when they don't, it don't matter how long I stare at em
does the racist girly work for you?
Nope, just a still photo
but that was the only format that came up, that or bitmap, but the forum wont let me attach those
must just be my lack of punctuation, I was using the same search, but somehow I didn't get the .gif format option
thanks
With videos that don't play at first on this forum, I "reload", and then the "play" arrow shows up and they play. Sometimes the video's just look like photos, so I don't even know they are videos until I use this trick. Don't know why it's necessary, using a MacBook laptop.
but MacBook even uses a surface
