GM coil pack question..
pishta
I know I'm right....
Tustin, CA
Anyone run a GM V6 (Silverado, G6, Impala...) that has this staggered 6 coil pack ,,'',, ? Question is do these sockets use standard plug ends? Reason I ask is that these coil packs have the ignitors built in (!, kinda unique for a coil pack) for a much cleaner megasquirt/megajolt install that a few may be interested in. Most coil packs do not have injectors built in, but this one does. If you get the high current switching ignitors off the PCB and out of the enclosure, there is less 'noise' on the board for ignition problems, and they can just take a low 5v signal out to trigger these. Think of them as LS type integral ignitor (>2 pin) coils in a 6 cyl wasted spark package.
