GM HEI with stock gm coil
player1up
orlando FL
Ok so I picked this up at the local yard and was wondering what the wire colors on the coil mean. I've got the ones on the module figured out to be this
Pink/black stripe: 12v ( + ) power supply
White: signal from dist
black: ground from dist
white/black stripe: coil primary ( - )
But what is the pinout for the coil? I'm guessing this:
solid Pink (peach) is what?.... tach signal? flux capacitor signal? :)
ok so I found this but now I'm more confused. Would the ignition control module be getting power from the coil? it looks like they are tied together inside the coil, I'm going to test for continuity.
I guess only because it was in a neat package that I could just bolt to the inner fender. I'll be trying it out in a couple of days. I hope to be wiring it up so I can just plug it in to test but still be able to fall back if I have to.
