rch105
Active Member
What should I expect to pay for a used, bare 489 carrier and a Borg Warner Spin Resistant unit?
I think @RustyRatRod might disagree with you on thatBorg Warner anti spin LSD shown is a friction tapered cone type. Non rebuildable. Unless you know its history, best to stay aways
Maybe so. I stick by my opinion. Pass. Ditto on the 489. You can find more common 742 prob cheaper. Will work fine for everything but an all out drag car with slicks.I think @RustyRatRod might disagree with you on that
the cone type can indeed be serviced and rebuild, it just takes a little more hotrodding then the clutch style does
Doesn't the 742 have larger bearing and it has a course spline input shaft. I would think it's stronger then a 489?Maybe so. I stick by my opinion. Pass. Ditto on the 489. You can find more common 742 prob cheaper. Will work fine for everything but an all out drag car with slicks.
To answer your question is "yes" if the LSD is in working order IMO. But as some of us have been saying you can get everything new for not much more that.Thanks everyone for their opinions and inside info. I don't want this to sound unappreciated but all I wanted to know was simply, what is a fair price to pay? Is $400 for both reasonable in today's world? I realize everyone's use is different but I don't care about that. Thanks.
Did you ever see the episode where boy Wonder gets his license and Batman gives him a 66 a body convertible...
OP, I don't think I'd give more then 250 for a good used cone carrier. Personally I'd want to open it inspect it for wear first. 400 for both in good or excellent used condition would not be bad IMO.Is $400 for both reasonable in today's world?
Well, not necessarily. This works for me...A489 case requires a crush sleeve in the pinion. This is a one time use part.
Not that I recommend it, but there is an unconventional way to run a "742" R&P in a "489" case.What does not enter change are the gears and the bearings.
