Badart
Senior Member
Thanks for the article 340sFastback. http://www.hughesengines.com/TechArticles/6408416strokerdynotests.php
I am thinking about copying their 2nd 408 build. Is this a good streetable combo? Is hughes stuff good? I dropped off my virgin 360 block and virgin 587 heads at the machine shop yesterday and dropped by today to show him the specs on the cam and tell him which rotating assy I want to use. He says it looks like a good combo and that he would look at it closer later. He is in the process of cutting the heads for bigger 2.02 valves and prepping the block. My plans for the heads are a full valve job, blend the bowls and gasket match. I know that I am leaving some power on the table by running these heads, but he says that they are in great shape and his machining prices seem good. What do you think?
