I've been seeing this type of question a lot lately. The distinctive lope sound that a cam makes the engine produce is caused by overlap, or the amount of crankshaft rotation in degrees that both the intake and exhaust valves are open, facilitating a ram effect in well put together engine (all parts working together to boost power within a specific (read high!)) rpm range. Do yourself a huge favor and pick your cam by your compression ratio, engine displacement, head set-up, carburetion and intake manifold, exhaust type and size, differential gear ratio, tire size and vehicle weight. You will be so much more satisfied. Give us this information and I'm sure that we can pick an excellent cam for your application. :thumbup:
