GotDart
I need to know the center-to-center distance for the fuel injectors on a 5.2/5.9 Magnum with MPFI. I would appreciate it if someone could help me out here.
I need the distances for 'A', 'B' and 'C' in this diagram, where the O's are the injector bungs. Please measure as accurately as possible with a steel ruler. I assume dimension 'A' is equal to dimension 'C', but need you to confirm for me.
O---------O-------------------O---------O
│«─'A'─»│«────'B'────»│«─'C'─»│
And while I'm asking, can someone confirm that the intake ports line up perfectly between a LA intake and a Magnum intake? I know people redrill the mouting holes and use LA intakes on Magnum heads... but do the ports REALLY line up??
