Slappy
I went to put this fuel pump eccentric on and noticed it has a keyway cut into it. When I installed it I lined it up with the keyway on the camshaft. The keyway doesnt come out far enough to engage the eccentric. In otherwords there isnt enough cam sticking out to engage the eccentric. Is this right?? If you look at the photo you will see the keyway.
