BarryC
'74 Duster 360
I pulled engine out and pulled it apart to re-gasket it to stop aggravating oil leak. Pulled the heads off to look at pistons. I forget over the years what was in it. They are kb 1279. They are a dished piston similar to the originals, but they seem to sit way down in the cylinder when at tdc. The block is still standard bore with less than 25000 miles since rebuilt 15 years ago. Calculating my compression ratio shows that I only have about 7.5:1 with the heads, gaskets, and pistons I have. Does this sound right? I'm guessing that is why I'm down on torque and power. Not saying that it runs terrible, but it doesn't run like it did before the major rebuild when it was original and untouched. Could I change pistons without doing another complete overhaul? Could I just change the pistons out to a higher compression pistons and put it back together with new gaskets? Would u use the same rings or new rings? Remember this doesn't have hardly any miles on it. The cylinders still show the good cross-hatch hone pattern with no ridge at top at all. I do remember putting moly rings in it back then. I'm hoping to get more performance than the factory gave me. Please help.
Thanks,
BarryC.
Thanks,
BarryC.
