I have some gas in the garage that has started to get a orange tint to it and that gas had stabil added to it 8 weeks ago. How is one to combat this? Pure gas in my area is like 3 hrs away.
I have looked at Edelbrock 1406 Carbs and they saw they are ethanol compatible. I will look at the initial possibly vacuum leak and resolve that, but if bad gas or ethanol related it will probably happen again. What do others do? Ethanol is all political and does nothing to benefit the environment. It benefits the farmers that grow corn in the Midwest, but is terrible for vintage cars.
It's not quite piss yellow just a real watered down Mello Yello color, but I thought it smelled different not like traditional gas.
The tube was about the size of an index finger. I tried about 6 times moving turning around as I feed it. I will try a smaller tube tonight.
I am not saying Shell is bad. I have always used them. Either a vacuum leak, carb issue or bad gas is my initial assumption.
We got E10 in 1999,and the community had no options at the time. It was 87E10 or 89/91 with up to 5% alcohol. So we have been forced to adapt.
I have found that E10 will hold it's color for months when stabilized at time of purchase, stored in a closed container, in a cool dark place.
I make good power on 87E10, absolutely no complaints.
You have to consider that E10 is up to 10%, and of that 10% you need about double of the alcohol to make the same WOT power,as you would with straight gas. And streeters run WOT very seldom.
At Idle and low speed the transfers and Mixture screws can easily overcome the slight leaness that might occur. And Part Throttle is no biggie,either cuz you just step on the pedal a tiny bit deeper.Or bring in the PV a tiny bit earlier.And most performance carbs are fat on the idle circuit anyway.
I just don't know what all the hullabaloo is over 10% or 15% alcohol, from the consumption standpoint. Mind you, my S is just a SBM, and relatively tame.
As a Honda powersports tech,tho, I gotta tell you I drilled out a lot of idle circuits. Those Hondas, here at 900ft or so, could feel the E10 right away. And don't get me started on weedwhackers!
