Got the Cuda running!
BARRACUDA340S
MT PLEASANT IOWA
I finally took time and got the Cuda running again. I polished the intake and put new rocker shafts on plus put on the BIGS 1050 Dominator. It flat gets with the program now. I also went to the Mickey Thompson drag radials. They will pull the motor down when I hit second gear on the street. Pretty impressive. I think my clutch is getting a little weak? I think it let go a little in 3rd? I will get you guy's some pics this weekend.
So that's why we havn't seen you around here lately. You have been busy in the garage. Did you get the bent pieces in the rearend figured out?
Jack
I went with 275/60/15's it runs like it has an extra 50HP I'll take it back to the dyno and see if I improve on the old 545 atw's
yeah I welded new perches on and fixed everything. I boxed them in this time so they won't bend again something else will.
Brett can you get me a picture of your tires on the 9" rim ? I just put the same ones on. Want to see how the rim size looks.
