RobbAdams
Ordered a set of 14 x 7 wheels before christmas, Americain Racing outlaw II's. Took my car to the shop[ on saturday to get them mounted. The set I ordered was a 5 on 4 inch bolt pattern, as I had taken of one of the hub caps and measured the spacing. Turns out at some point the rear axel in this car must have been replaced, as the rear wheels are 5 on 4.5 aaaarrrggghhh! The owener says no problem he can send back the 2 wheels and order in a set of 5 on 4.5 for the rear.
While they are mounting the front right wheel one of the studs breaks off, and has to be replaced!
I warned the guy that the drivers side lugs were reverse thread, before I took it in. They proceeded to to destoy 2 lug nuts trying to take them off with the impact wrench. Of course he does not have any reverse thread lugs, so he replaces all the studs on that side with normal thread studs, ($2.50 per stud). Plus another $2.00 per lug nut.\
The two front wheels do look awesome, now I just need to get the rearts here so I can get them on! I will try and post some photos later on.
Robb
Robb
